Go Kart tires and wheels HELP.
Ryansway
Well this is the only thing holding me up from putting this go kart on the road and its killing me.....
Well first I have a 5/8 dead axle go kart and the wheels and tires are shot as are the hubs/ball bearings in the middle and rusted all over so im just gonna replace the tire and wheels but im having troble finding the drive wheel that holds the brake drum and sprocket that i have and i cant recall the bolt pattern right off but i was hoping some 1 could point me in the right direction, heck i dont even know the right term for that drive side tire setup, lol please go easy on me.
Ryansway
Ill post pics up tom after work, and its a semi off road cart.
Dont know the brand and ive looked it reminds me of the manco style but when i post maybe some 1 will know.
I would to find 2, 13x5or6-6"rim and 2, 15x6-6" rim but can not find a drive side sprocket and brake setup on 1 that big.
Ryansway
Okay maybe you all know a way for me to go with this I have a sprocket for drive side wheel with 5/8 axle hole, that has a 3 1/8 bolt pattern with brake drum to match and I need a 6 inch rim with a hub is can attach that to and im have no luck finding 1..........
jonboy
Owensboro, KY
Just out of your description it sounds like an older Carter Bros. but, without pictures we are of no help. Lol!
Double check the bolt hole circle, 3 1/8" sounds like an odd size but, it's very close to 2 13/16"...
FYI: Bolt hole circle is measured from centre to centre of the stud holes, diagonally across the centre of the rim.
I mentioned that because you may have measured from outside to outside; if you subtract the width of one stud hole (5/16") from your measurement, you end up with 2 13/16" :)
You need one of these & one of these
Ryansway
Hey jonboy it looks almost identical besides the key way, its a dead axle so its bearing i belive in the middle.
Ryansway
Fabroman yeah i did measure out side to out side and thanks agin guys for your help you guys are awesome, and im still working on pics, with my job i dont get off till late at night but im off sundays and ill make sure to post up pics.
firemanjim
Just kartin' around....
Houston Texas
:toetap05::toetap05::toetap05:
Ok, I'm gonna be watching for the pics...... :lolgoku:
JK.....
Poboy kartman
Senior Moments Member
White Settlement Texas
Good gosh man...did you never hear the saying...."don't look a gift horse in the mouth....."?????
Ummmmmm......Actually. ..I don't know what the heck that means. ......p
