Go kart sat, is sitting
Ryafor
Carb is prob full of fuel. Tank has some gas in it still. I couldn't get to it but come spring is there any additives or anything I should add? Injector cleaner or anything to the tank? It's a lawnmower go kart. It's not home made. It's one of the mowers that actually looks like a go kart. Its outside in the elements but covered with a tarp.
GavMasterG
La Grande, OR
Just give the carburetor a cleaning and dump out the fuel in the tank. Just give it a clean through and it should be fine. If it runs a little rough, try brushing the spark plug up a bit. If it runs smooth and maintains an idle, you should be good to go.
-GavMasterG :thumbsup:
Poboy kartman
Senior Moments Member
White Settlement Texas
If you go to my gallery and see my $20 kart...it has never been indoors...or covered....so...
You may have to get a new carb...but then again...maybe not...
My neighbor had a tiller that was rusted up bad in the carb and tank... some CLR, then PB Blaster, carb boiled in lemon juice....and it runs....the idle is a little rough, but seeing as that carb costs $100... we're both fine with a little rough idle.
Jrgunn5150
Rudderless
Diesel fuel works pretty well to clean thing's out also.
Honestly, i would just try to crank it as is first, it might start and run, never know.
Ryafor
Thanks. I just came back to BUMP this thread. I never noticed there were any replies. It may be fine idk. The engine and most the kart was covered. I just know I filled the tank before winter so the kids could ride it but they didnt ride it long before we put it away. My only concern when I made the post was that the gas I left in I got gunky. I was just wondering if I should add some sorta injector cleaner or something to it. I don't plan on taking apart the carb, replacing it or cleaning it if I dont have to. It's been sitting with fule in the tank and carb since I think the beginning of November. TBH I have no clue how to empty the tank or the carb aside prob syphoning the gas tank. I don't really want to but I think I'm going to try and sell it. I figured it out to be about $300 Canadian to buy a new MCP brake kite for the build I'm working on now. Im in a small basement apartment and the kart I'm currently working on has been sitting on my living room table. Im going to be adding the axle and rear wheels soon and wont have room to keep it inside and the landlord (lives upstairs) definitely wont want me keeping 2 karts here anyhow so basically I'll be trading it for brakes for the new kart. Haven't tried anything out yet but maybe later I'll see if i can figure out how to drain the carb and will empty the fuel tank. I see so often stuff for sale that "runs great" (carb just needs to be cleaned) and I don't wanna be one of those sellers
Poboy kartman
A little story: I have a 2002 Ford Escort that sat up for almost 2 years...it started right up...(after a new battery) ...I pulled it up on ramps to fix the power steering...
It wouldn't start after I finished....got help to push it off the ramps...next day...did some carb cleaner shooting and it went from pop pop to running after a dozen shots....
I added fuel injector cleaner and idled the car....(wasn't legal to drive....and didn't want to wind up on the side of the road) ....until it was nearly empty...added fresh gas and injector cleaner.....ran ot long enough to clear codes, and it's been running like a top.....( close to six months now).....
