firemanjim
Just kartin' around....
Uhm, them are 6 lug wheels in that link....
Its hard to tell from the picture. Are those small holes threaded for studs? You can run either 3/5 holes rims on that hub.
What??
How can a three bolt pattern wheel match a five hole pattern hub?
It's either 72° or 120° hole to hole...
even skipping a hole of the five bolt pattern would be 144° and not 120°... *shrugs*
Am I missing something here?
[EDIT]
DWT catalog
http://ftp.dwtracing.com/Public_DropBox/2013DWTCAT.pdf
AS far as I can tell they make numerous bolt patterns, just give them a call; I'm pretty certain they can provide the wheels you need.
Unless my math is wrong a five bolt pattern will be 60 degrees apart. On my new toy I am building, I am running 5 bolt rims on three bolt hubs.
Double edit: tapatalk sucks... I reply to something, and it looks like I'm stating the obvious because when I refreshed the thread, there weren't any new posts... then after I post, there is a post or posts that didn't show before... making me look like more of an idiot than I already am. *smile*
your math is wrong!
a full circle has 360°, 5*60 would be 300.. you missed one step or end up having a six-bolt circle.
only way to end up with a equally spaced five bolt circle is adding 12° (60/5) per step .. hence 72°
What??
[EDIT]
DWT catalog
what he said
No need to feel bad if your intentions are good.
everyone makes mistakes sometimes,
and we are many.. so we can clear things up if one is in fail-mode
Oh, I'd be interested in your pictures.. and it's really easy:
find the folder you stored the images on your computer (and remember)
click the "Post reply" button under the last post.
The blue one on the left, not the grey "post quick reply"!
Scroll down a little until you see the "Manage attachments" button, click it.
In the appearing pop up, click one of the topmost five textfields;
navigate to the previously ,mmentioned folder and add an image..
click upload.. and wait for it to complete.
Now all you images are on DIYGK server and are already attached to the post.
Now scroll up, type your text, and click post reply...
done.
