South Kart3377
Kart designer
I am switching engines and transmissions, and would like to sell some of my old parts.
Here is a list of what parts I have available:
Picture 1. Walbro LMT Carburetor, this carburetor came off a Briggs 17.5 lawn mower. It has had its choke removed for performance and Anti-Fire Nut. $13.00
Picture 2. Briggs and Stratton Ignition Coil, came off a model 19 (8HP), this coil is good, but does need the plug connecter bent to fit your spark plug. $1.00
Picture 3. Briggs and Stratton Ignition Coil, this Coil came off a 17.5HP Lawn mower. The boot locks on to the spark plug with a click sound. $3.00
Picture 4. Briggs and Stratton Flo-Jet Carburetor, the top half was rebuilt a couple months ago, the bottom needs to be cleaned. $20.00
Picture 5. Briggs and Stratton Connecting Rod part number 390401. $1.00
Picture 6. Briggs and Stratton Model 19 Camshaft (used) $10.00
Picture 7. Briggs and Stratton Model 19 (ball bearing on pto side) Crankshaft (used) $15.00
Picture 8. Briggs and Stratton Model 19 Head (Used) $3.00
Pictures 9/10 Briggs and Stratton Model 19 Block, this block is Kool-Bore with bushing on flywheel side. It needs to be honed to over size due to Vertical lines. $20.00
Picture 11. Briggs and Stratton Model 19 Sidecover works with ball bearing crankshaft. $7.00
Picture12. Briggs 17.5HP Flywheel, Cast Iron with Plastic Fins. 10.00
Pictures 13/14. Comet 40 Series Driver, has been taken apart cleaned, lubricated, then put back together. $90.00
Picture 15. Briggs and Stratton Model 19 Carburetor needs top half rebuilt, main nozzle threads restored and adjustment screw replaced. Does not have choke. $7.00
SOLD Picture 16. Live axle with pillow block bearings, 4-bolt sprocket hub and band brake. $13.00 SOLD
I will give any diy go karter this deal The 8hp block, Coil, Flo-jet carb, con rod, cam, crankshaft, head, sidecover and 40 driver for $155.00
If any one would like the whole lot its $160.00
Pictures 11-16 will be on the next post.
Hopefully we can do some business. I will edit this post as each item sells. SHIPPING IS NOT INCLUDED ON ANY OF THESE.
I NEED THESE PARTS TO SELL, I WILL NOT REFUSE ANY DECENT OFFERS!!!!
PM me if interested
South Kart
PM me if interested
South Kart
