Go Kart not starting
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Ok so back in July, me and 3 other friends went off road and I took my relatively small go kart with them to the Turnpike which was stupid right off the bat, but anyway, while we were there, the power switch (?) on the engine broke and now it is stuck in the off position. So I'm guessing the switch is broken. Bottomline, the spark plug doesn't make a spark. How do I go about this? I imagine I have to replace the switch and I don't know where to get one. Also, it's not the spark plug. I tried it on an identical engine, and it shocked me lol. I'll take a picture of it.
kendelrk
redneck engineer
westland michigan
its clearly that, its probablly stuck, tap it lightly with a hammer, if all eslse fails you might want to disconnect it
anderkart
Surprise Arizona USA
You might get your old switch working again by spraying some electrical contact cleaner with lube (or even WD40) into the thin gap between its rocker and housing. Then working the switch back and forth.
But If that doesn't work: You could probably buy a replacement at Radio Shack, or just wire up a metal toggle switch up near the steering wheel so you could reach it in case your throttle stuck while riding.
