Go kart moves while idling XTK-710E
FreeRunner15
Get yourself a longer belt, boom, problem solved :thumbsup: .
---------- Post added at 02:53 AM ---------- Previous post was at 02:49 AM ----------
Appears to be (while camera isnt looking)... appears to be HE is pulling on the throttle cable. This video is a prank to fool you all into thinking there is something wrong. Everything sounds perfectly fiinee
I think you should stop posting advice!! You do not know what you are saying at all. Get a longer belt?? Are you for real?? If you had a clue, you would know that you need a specific length belt for a specific centre to centre distances. You cannot just get a longer belt
Please refrain from posting advice until at least someone with knowledge has posted before you....and then you can just say the same thing
FreeRunner15
YeaHH! :iagree::auto:
MalakyTags
I just wanted to update everyone on this thread. I do apologize for the delay however, we all know real life can get in the way of our golden go kart dreams. As it turned out, the issue causing the wheels to continuously move was indeed within the torque convertor. One of the roller weights had moved out of position (probably from being jarred pretty hard) and actually created new grooves. The new grooves basically caused the roller weight to continually pop out of the correct position thus keeping the torque convertor always slightly engaged. I bought a brand new comet series TC and everything is fine now. Thank you everyone for your help!
