Hi,
This is our first time building a go kart and we want to make an electric go kart with the rear axle as a live axle. We have bought the following wheels:
http://www.harborfreight.com/10-inch-pneumatic-tire-30900.html
The bolts (which are 2 inches apart from each other) come out. The only problem is that there are wheel bearings. The inner diameter is 5/8 inch.
and we plan on using this as the axle: http://www.truckspring.com/suspension-parts/hardware/steel-threaded-rod/5-8-inch/TH-58X40.aspx
The ends, approx. 4 inches, will be threaded
For our sprocket, we plan on using this:
68 Tooth Rear Sprocket For #25 Chain
5-1/2" OD, 1" ID. 3 bolt mounting pattern.
Item # SPR-2568
We were planning on using flanges but we cannot find threaded flanges that would work. For this project we want to minimize the amount of welding necessary, but we will probably end up welding the sprocket on (which will also require a flange). Any suggestions? Thanks!!!
Item # SPR-2568
