big steve
I bought a kart off of craigslist for cheap, but the guy was in the process of converting it to a live axle. He cut off the axle stubs. this is what I think I need:
an axle: http://www.mfgsupply.com/m/c/AZ1411-36.html
a new 3/4" clutch: http://www.bmikarts.com/item/Clutch---41-3-4--400941-3161
a bearing kit: http://www.bmikarts.com/item/1-Rear-Axle-Assembly-400410-6230
a sprocket: http://www.bmikarts.com/item/54-Tooth-41-Sprocket-801210-1150
and a hub: http://www.bmikarts.com/item/Steel-Mini-Hub-AZ2561-6012
or I could get this instead of a sprocket and a hub:
http://www.bmikarts.com/item/41-Sprocket-45T-w--1-Bore-400227-6987
I'm going to be putting 18" turf tires on it, along with a 6.5 HF
What I want to know is if this will work, suggestions, and whatever. Any help is greatly appreciated!!!!!!
p.s. I am new to karts, but not to engines
