Go kart gearbox
cspaghetti97
Hello i own a yerf dog gx150 and have previously purchased a 440 snowmobile engine to mount to it. It will make it extremely heavy and hard to move backward. So i was looking for a gearbox that had reverse and 3-4 forward gears if anybody knows of one please let me know
thanks
soggycrashed
Honolulu
As far as I know, only motorcycle engines, dirtbike engines, and lawn mower engines will give you gears. There is a forward/nuertral/reverse gearbox for a comet torque converter.
Swabbster
you will rip a comet gear box out real quick using a 440 2 stroke, another option is set up a starter generator, it will start it and recharge your battery, but you could fire the engine up backwards, for reverse,
Some older, 2-stroke golf carts use that method to accomplish reverse.
To the OP- Without a ton of cash to throw at a machine shop, you're basically S.O.L.
A sled engine should use a CVT. This eliminates the need for a multiple speed gearbox. For reverse on a sled unit, you're really best to get a donor sled that came with reverse and steal all the guts. I doubt you could retro-fit it.
In my experience, you don't really need reverse. Planning where you're pointing the kart certainly helps.
Swabbster
yes 2 strokes can be spun backwards, they may have a little less power because of the timing, but you don't need all about 50hp going in reverse,
cspaghetti97
Go Kat Transmission
I am putting a 440 snowmobile engine on my go kart and want reverse and a few gears because the machine will be so heavy and i cant seem to find one that is chain driven that is heavy duty enough for a 440 motor....any ideas.....i would like at least 2 gears and reverse
Thanks for the help
