go kart gear ratio
harry
ive just bought a 200cc ghost motorbike engine with 5 gears for my off road go kart. i need help on deciding what gear ratio i need so how many teeth on the engine drive sprocket and how many on the axel sprocket. the go kart has 18inch rear wheels but its quite small and also id prefer to have a bit of a better top speed than acceleration thanks.
firemanjim
Just kartin' around....
Houston Texas
:welcome2: well, you gave us almost all the pertinent information..... How tall is the tire? What did the bike have as far as rear sprocket and tire?
In all honesty, IMO, if you have say a 50 tooth rear on kart, drop to somewhere like 38-42..... It's still gonna be kinda slow compared to bike, that had probably like 27-28 teeth..... You want some torque though cause you have more rolling resistance..... Try a 38 and go from there. You will most likely find it works good on take off and it's still plenty fast on the kart. Leave the engine sprocket alone for now.....
I could be wrong though. I normally use the same sprockets from the donor bike, as long as the weight of each vehicle is close to the same..... Otherwise, I drop down, according to weight, and it's really trial and error till I find what I really like......
I'm putting a 125 in a kart I built originally with a 70cc 3spd.... I'm gonna use the original 70cc axle sprocket for now, to see how it likes having a 125cc 4spd on it. Then I'll go from there......
The 70cc engine is from a Honda atc and the kart is a home built number..... With 16" tall off road tires....
In all likelyhood, the 18" kart tyres are still smaller than the original bike wheel so, using the same sprockets will already increase top speed over the bike...
what happened to the 125cc Honda?
but it's the very same idea..
get to know the primary reduction, the gear ratios and see where you end up;
then use that number to find out where you need to set your final ratio.
harry
ok thanks for the information guys i will go with a 38 tooth to start off with and go from there. oh the honda... my frtiend was unable to find the casing for it...
