Passionfruit1965
Hi there! I am currently working on my first build so I am quite new to this and have a couple of questions I was hoping to get some help with. I am planning on buying a Predator 6.5hp engine my for go kart. I purchased an axle setup on eBay. The guy was going to build but didn't have the time. Here are my questions...
1.Axle came with 36 tooth #40 sprocket, I was looking at a 10 tooth clutch for the engine. That would put me at a 3:1 gear ratio if I'm correct with my math. I will be riding on grass/some bumpy terrain. Nothing crazy or mountainous. Will that be okay or should I look at a bigger sprocket for the axle?
2. I have been reading a bit about clutch converters. Given the information above, should I invest in one for the predator or is it unneeded? Pros/cons?
3. The axle setup came with locking collars. Even though I have those, should I still weld the sprocket on the axle or is it okay just with the collars?
4. I plan on getting a header pipe for the engine. Are there any other mods for the Predator that anyone would suggest?
Any answers or tips would be appreciated! Thanks!
