Go kart engine problem after oil change
MotorBannana
I have a homemade off road go kart and its powered by a 9hp Subaru generator engine.it was working fine but i decided i should just change the oil just in case because it was black.i found a bottle of 4 cycle SAE 30 oil and put it in but it wasnt enough so i found another brand of oil,same sae 30,and put that in but it still wasnt quite full so i got some of the old oil that was in the engine when i changed it and put that it and it seemed full so i was ready to go.i didnt know what typeof oil was in it before i changed it.anyway,i went for a ride to my friends house and it was working fine with a noticeable amount of torque and speed until about 3/4 of the ride when it started acting like it was running out of fuel.i made it to my friends and got out turned it off and noticed it was hotter than it usually gets.i went inside and did the usual play games and crap like that.then when i decided it was time to go i started it up and immidiatly the idle was high but i thought that was normal until i got in and tried to gas it.thats when it started acting wierd.i would gas it and about 1/4 through throttle it would immediately loose power and make sounds like it was either on high choke or running out of gas.it has a brand new spark plug and the carburetor and needles are clean.please help I've done as much to try and fix it as my knowledge goes and it hasn't helped at all.
Poboy kartman
Senior Moments Member
White Settlement Texas
:iagree: It's more likely just coincidental.....unless you knocked something loose while working on it .....but doesn't sound like an oil problem....and a little bit of the old oil shouldn't be a big deal.....
Poboy kartman
Why bother to change it at all then, especially when it's black?
As a doctor once told me they taught him in medical school...."Dilution is the solution to pollution ".....in other words....a drop of the most deadliest poison on earth becomes harmless when dropped in the ocean....."
Soooo.....oil becomes black because it becomes contaminated.....instead of being 100% contaminated....its now only slightly contaminated.....
If you don't flush the engine.....you are going to have a percentage of old contaminated oil in the mix anyway.....
Doesn't sound like he could have added much old oil.....and a mix of fresh oil with a tiny bit of the oil it was already running with beats the heck out of running it low.....or on the old oil.....
I'm not getting your logic here.....(probably because it's missing) ....
ML-TOYS
long island, new york
I think this is considered "ideas as you ask for"
Putting in old oil is never a wise thing to do, but has nothing to do with engine running lean.
Thoroughly check carb and associated parts for leaks/clogging.
KartFab
Dallas, TX
You probably have a dirty carburetor. As Russ pointed out the engine was probably running lean, and now it's just not getting enough fuel.
Fuel delivery problem
1) empty gas tank and hose line
2) wash out tank and line with fresh gas
3) thoroughly clean carb, reassemble.
