MotorBannana
- Messages
- 3
- Reaction score
- 0
I have a homemade off road go kart and its powered by a 9hp Subaru generator engine.it was working fine but i decided i should just change the oil just in case because it was black.i found a bottle of 4 cycle SAE 30 oil and put it in but it wasnt enough so i found another brand of oil,same sae 30,and put that in but it still wasnt quite full so i got some of the old oil that was in the engine when i changed it and put that it and it seemed full so i was ready to go.i didnt know what typeof oil was in it before i changed it.anyway,i went for a ride to my friends house and it was working fine with a noticeable amount of torque and speed until about 3/4 of the ride when it started acting like it was running out of fuel.i made it to my friends and got out turned it off and noticed it was hotter than it usually gets.i went inside and did the usual play games and crap like that.then when i decided it was time to go i started it up and immidiatly the idle was high but i thought that was normal until i got in and tried to gas it.thats when it started acting wierd.i would gas it and about 1/4 through throttle it would immediately loose power and make sounds like it was either on high choke or running out of gas.it has a brand new spark plug and the carburetor and needles are clean.please help I've done as much to try and fix it as my knowledge goes and it hasn't helped at all.
It's more likely just coincidental.....unless you knocked something loose while working on it .....but doesn't sound like an oil problem....and a little bit of the old oil shouldn't be a big deal.....
