go kart ****ed me off
xhebrailduka
Im just put a new bolt on it was a 2 inch bolt i believe same size just not sure if the threads are gonna keep it held. But now the torque converter belt doesnt even move.
---------- Post added at 02:23 PM ---------- Previous post was at 01:56 PM ----------
I will see if i can do it maybe by then end of the week ill try to fix it. If not then i might either store it for later or sell it
Jamming a new bolt into a screwed up hole is just going to make things worse.
Just clear the threads out. Get the right tap(typically the tap has the right drill with it).
Use lots of real oil... Go slow... Drill and then re-thread the shaft..
xhebrailduka
What if i take the thread out like you said and just find a way to keep the boly there without moving i dont know what exactly maybe some gorilla tape or something maybe just to keep it from coming put
Dude you really need to work on your typing...
It's not that "simple"... The threads are damaged... Cross threaded with what ever you put in there...
Once the hole is rethreaded, with the new bolt, you'll need to use BLUE lock-tite, that will hold the bolt, but allow it to be removed for service.
xhebrailduka
Ok i will try what. But after i remove the damged thread in the shaft. Dont i have to rethread it again? Or do i just put the bolt on with the blue locktite?
There is going to be damaged shaft and bolt thread bits, like little scythes... Clear out those bits... Run a corse thread tap with plenty of oil...
