Go Kart Differential
mbennett66
If you were going to use the differential axle (Part # 1369) from Northern Tool, does the sprocket bolt directly to the differential or just like any other live axle shaft with a hub.
If it bolts to the differential, I guess that means the motor is turning the differential housing....?
