Revlimiter
I have a go kart with a 7hp HF predator and i installed a 12 tooth max torque clutch with a 60 tooth sprocket on 1 wheel drive and the clutch starts to smoke a lot after just 1 minute of riding. it also started to make this ching/cling noise after i was heading to my garage. didn't ride it a lot just first time after rebuild and yes its a one wheel drive cart. i bought the frame off of Craigslist for about 60 bucks, it just needed one spot to be welded since who ever welded it wasn't good at welding. also it came with a 13 tooth it think it was comet clutch and a 72 tooth sprocket except no chain. they said the motor blew. I think they were using a clone 6.5hp engine also because the mounting holes on the plate are the same to the HF predator holes. the chain I'm using for my setup is a 35 link the previous go kart frame owner used a 40/41 chain for their 72 sprocket and 13 tooth clutch setup. I don't know what to do, i think i go up higher in gear or get a jack shaft, except there is no room for a jack shaft. My friend is selling a couple of sprockets from his old go kart projects for really cheap prices so i might buy a higher gear axle sprocket and keep the 12 tooth clutch. any help would be helpful. Will a 72 tooth axle sprocket work?
