kart_goes_brrr
- Messages
- 124
- Reaction score
- 89
Yyyup, I just wanted to see if there was any other shortcut. HurrayySand paper, wire wheel on a drill or grinder and sandpaper are now your new best friends!![]()
The only shortcut I can think of is paying to have someone else do it or paying for a large tank and lots of chemicalYyyup, I just wanted to see if there was any other shortcut. Hurrayy![]()
Yeah fair enough, sometimes it's both too. I'm currently preparing a plan on the restoration, also quick question, I've noticed my chassis is quite bent, is there a solution?With this hobby, you either make lots of effort or spend lots of money.
Someone should really be able to have eyes on it to make that call. It could be as simple as, "bend it back" or bending it back could structurally weaken it to the point of failure (randomly).Yeah fair enough, sometimes it's both too. I'm currently preparing a plan on the restoration, also quick question, I've noticed my chassis is quite bent, is there a solution?
Lol that was exactly what I was thinking about when I mentioned the big tank and chemicals.Get with that guy on Youtube that dips entire car bodies into a solvent bath. Takes 99% of all the paint and primer off and shows the rust, body repairs, Bondo, etc.
Woah the results are Insane! Really nice job! I'll write this as plan B, because I think I'm just going to send the chassis to a sandblasting service and then paint it. It's probably way less work that way.Wire brush in a drill and washing it off after then primer and paint. The little red rocket is to much fun!View attachment 164894View attachment 164895View attachment 164896View attachment 164899
I seen on the minibike forum, someone talking about brake fluid and trans fluid mixed with something to make it sticky, that he liked to use for rust removal. I cant seem to find where it was. It was in new posts about 4-5 days ago.
Can anyone confirm or deny this?
Yea, that was it.I think I saw it and posted in the thread. Was "Ed’s Red" mentioned? It mainly serves as a solvent when you mix acetone (or some other highly volatile, quickly evaporating solvent) with ATF fluid. The ATF (automatic transmission fluid) makes it sticky or less evaporative....
Noted, I think I'll figure it out for the paint, maybe even get it powder coated if it's in the budget (highly doubt it). And I finally disassembled the kart. But, I have more questions now. First, how do I repaint this nose? I tried painting it with spray paint at first and as you can see, it was a terrible idea. Do I just sand the old paint and repaint or is there a better solution? And also is there anything durable enough to not crack while being exposed to the sun and rain? (I mean like a type of paint)Wow, do it man. Do it. You have to be ready to paint it after it’s been sandblasted or it can flash-rust if you wait too long. If anything, spray it with primer ASAP.
And finally, the rust on bolts and stainless steel. I've put all the bolts and nuts in a bucket, I can sort out the okay ones and the rusted ones, but for the rusted ones, is putting them in vinegar effective? Or is there a better mixture?
And for the stainless steel, it has some rust spots and these white bloomy spots, how do I remove them?
Whoops, didn't see this, looks like it answers the question about the chrome plated stuff. To be honest, the goal of this restoration is to make it look absolutely brand new (not out of the factory new, but no rust and stuff), So that when I will sell it (pretty soon, because I'm growing a bit quickly lol), the profit is going to be pretty high. Also whoever repainted this chassis just painted over a first layer of blue, and it's not even the same color, so it looks really ugly whenever it chips and scratches. I'm actually going to remodel the brake caliper support because it's blocking the frame, and weld all the stuff I need BEFORE sending it to sandblasting, so I think it won't be necessary to work on it with a wire wheel and everything.Hey kart_brrr, your kart frame is not the worst I have seen, BY FAR. I mean it’s pretty decent looking (from 10 feet away, lol). I looked at the photos and the only thing that really stands out to me is behind the seat on the left and those large unpainted steel parts: the custom brake caliper holder and the engine/chain guard. Those could be wire wheeled, mechanically sanded with a flap disc, etc and primered and painted with a few coats of cheap spray enamel.... You could either color match those parts to the new chassis color or paint them black or whatever you want.
There’s rust on other minor parts like the side pod holders or nerf bars, spindle arms and the rear axle, those upset my OCD mind a little and I would address those. Whatever is chrome plated, rub it with some fine steel wool, maybe wetted with solvent, and the chrome can come back. You might keep it lightly oiled or clear coat it to keep the rust away. Won’t know the real condition of the kart chassis until you remove everything. I bet the underside is scratched up pretty awful.
Short version; just do a touch up on the bad parts. If you intend to repaint the whole thing, just treat (de-rust) the rusted areas and lightly sand the existing paint and paint over it. I often do a refurbish with as close to the original paint as possible, so if/when the new paint is chipped, it shows the same color underneath.
