sylvaner
IT CAN AND WILL BE MADE
G'day today my victa go kart axle was made.
They use a piece of hollow tubing about 2-3mm thick and welded high tensile steel bolts at the ends.
Anyway I was at the go kart shop checking out sprocket mounts and I showed the guy my axle.
He was shocked, he said there was no way that this axle would be strong enough.
He said that high tensile steel welded to another type (not sure what type of steel it is) would crack right away and I would pretty much die.
Anyway I wasn't so sure, it looks strong enough from my point of view plus I weigh 65kg so I should be light enough.
So what do you think?
http://www.youtube.com/watch?v=gN5lV2BsQA8
* 27mm wide at shaft and 16mm wide at bolt ends.
