I just stumbled upon this ..
finally another math addict
Anyways,
jrbrtsn, I'm sorry.. but there's one major flaw I'm afraid:
The TC has an efficiency of (at best) 80% due to the belt and such..
which you missed to take into account
40% road inclination is quite a substantial amount;
so 700lbs that's ~317.5 kg to climb a 40% (22°) slope
you'll need 1200 Newtons of power (1168.6 to be precise [262 lbf])
doing so at only 4m/s (~9mph) would require 4674 Watts of power (6.3 hp)
and there's where the TC efficiency will break your neck (leaving you with no more than 5.2 hp)
with 2.5m/s (~5.6mph) you are within the power provided; true...
but keep in mind that the TC eats incoming torque; so the from 11Nm @2500 rpm (8.1 ft lbf) No more than 8.8NM (6.5 ft lbf) will be at your disposal
Once the belt starts slipping all is lost.
So, if you really need to climb such steep hill, then you'll need to readjust your gearing I'm afraid.
Anyways,
