roddles
I don't mean to be critical, but you have to much heat in your welds on the last pic. To much heat will make the metal weak and prone to breaking. You are doing a fine job.
Hi DaiSan76,
What brand and the engine hp used here?
I like the way that you installed that brake of yours. Very clever. Have you got any idea why it is now working as it should?
Harbor Freight Predator 6.5 HP.
Thanks. My next design will use the same HP but not sure whether they have the same capability because mine is not branded engine. Mine is Chinese made gasoline engine.
By all means, critique my work, that's what I have pics up here for. I have all of about 30 minutes of welding with wire feed. You reminded me that I took more pictures of my brakes that I wanted to post up.
Daisan76,
Looking at your kart, may I know a few things about it:
1. Diameter of your rear shaft?
2. Diameter of your rear wheel?
3. Diameter of your front wheel?
4. The speed of this build
Sorry if I did not follow-up closely the discussion and may repeat the questions asked by other members.
You know that I like big wheels and working on the same type of build. The best thing with the big wheel from what I like they are all the cushion and shock absorber.
