go cart engine connected wrong?
gokartlover94
I have a go kart with a Honda GX 120 engine when I move the lever that is connected to the engine that doesn't do anything I have a spring that I put on a black knob attached to the carburetor and once the knob is twisted the go kart will start moving but it will not move if cconnected too the swing arm on the engine. Whats wrong
Welcome to the forum.
In case you haven't noticed by now, we loooove pics. Two reasons:
1. We like to see what you're working on &
2. We like to see what you're talking about without having to visualise it :huh:
"A picture tells a thousand words" as the old saying goes; give us a few thousand words worth & we'll be more able to help you :thumbsup:
Poboy kartman
Senior Moments Member
White Settlement Texas
The "swing arm" is the governor, which "governs" how fast the engine runs. It should be hooked to a part that moves by the throttle cable with that spring. How and where are critical, as there are usually several options. Much as we can help without pictures.
