getting the best out my engine?!
r_chez_08
Should be in the shop...
Cornwall, UK
See it here?
Remove the two nuts holding on the plastic housing to the carb, install thick rubber coated gasket if one is not already present, slide on new billet adapter, slide filter onto adapter and tighten jubilee clip.
If you find the adapters are too pricy I could get an adapter and filter to your door for £20 if you wanted. I could make a simple one on a lathe. It would be like the one in the pic above on my kart, except with some improvements.
Or alternatively, get a tuna can or similar (like a round baccy tin), drill the neccesary holes and mount it on. Then attach the better filter to this. Not ideal, but works!
If you want to get some more power out of the gx140 you could also install a clone carb and camshaft.
Solidshot
Ahh its actually quite a thick piece of metal then? the picture makes it look like a thin plate and it jus confused me a lil. Nah ill just buy the adaptor, thanks for offering though bud :)
Whats the difference between my current carb and a clone carb?
r_chez_08
Cornwall, UK
No probs, the import postage may be horrid though.
Fancy adding a billet steel flywheel to yer order? We could go halves on postage ;)
The clone carb probably has a larger bore and therefore it can flow more air and fuel. You could alo put a clone 14cc head on cos they have larger valves.
Or start with a clone nd sell the gx140?
Solidshot
Wouldnt a new jet be more ideal for that? or does the jet only control there flow of fuel? When you say a head?...expand on this? did you mean 144cc also?
At the moment i just want to be able to make the very best of the gx140, just to say ive acoomplished it to be honest, but once its done and im happy with it, the chances are, im gna sell it. I want to be a bigger/more powerful engine for my off road kart, and then prehaps and nicely modified/tuned gx140/160 for a race kart :)
r_chez_08
Cornwall, UK
Yeah you could just rejet the carb. Get some precision drills from eBay and drill them yourself.
Don't worry about the head. However you could get a thinner cylinder head gasket or mill the cylinder head. This ups the compression.
Solidshot
Yeah I think I may drill it myself depending how much they are gna cost me lol
What do I search for? Jus seems like carb drills wont be precise enough for eBay lol
Solidshot
Thats all?! Jesus i had visions of them costing a good 40-50 quid! Ill just have to hope they are still there on pay day lol I just sold the first kart today and am hoping that it is picked up on thursday so ill get to work on my other one asap!
Going to take the engine and everything else off! Paint the frame, possibly buy a new seat, get a new exhaust, air filter! Do you reckon i could get just a thin head gasket off ebay? or am i looking at having to go to a website that specializes in karting gear? Also all these customisations that have been above mentioned, it may sound like a stupid question but will they give me more speed? Cos id be lying if i said i didnt want more speed lol
Seriously, that depends on how deep your pockets are. In theory, you could get 10hp out of it but it will cost you at least a grand...
It's better/easier to shave the head than hunt for a thinnner headgasket. If it blows, there's no guarantee you'll be able to get another one exactly the same in the future.
Having said that, one option is a copper head gasket, but it will cost you...
Top speed will only change if the max RPM does. Everything you do will add more torque but, if the governor is left intact, top speed will stay the same, you'll just get there quicker.
As it stands, removing the governor alone will increase top speed by increasing the max RPM from 3600 to somewhere around 5000 at which point your valves will start to bounce.
Edit: I think chez may have missed your comment about the head. That wasn't a typo, he did mean 14cc head, that's the capacity of the head alone. A smaller head capacity means a higher compression ratio which gives you a bigger bang.
The head is the bit that bolts on the top with the valves in it, below the cover with OHV stamped in it
Solidshot
Shaving down the head? I don't have access to any lathe? I keep reading the link posted above about removing the governor and watching videos on YouTube about how to do it, I'm jus worried about taking the side off and F'ing all the internals up! Also something my old man said about the oil, what of the previous owner didn't put the correct oil in? What of I then go and drain the oil and put the correct stuff in? Wont that screw it up a whole lot too?
Good coz it's not done on a lathe, it's done on a milling machine. I have experience on both lathes & mills btu this is one thing even I'd leave to the professionals.
Two options:
1. Take your time, be careful & pay close attention to what you're doing. It helps to have some kind of written instruction (like a workshop manual).
2. Leave it alone until you're more confident.
Putting the wrong oil in it can cause problems. If it hasn't been long term (I'm talking years), switching back to the correct oil will not cause any problems & may actually solve a few
r_chez_08
Cornwall, UK
If you decide to take the side cover off nd there are deposits inside, clean the block with some.mineral spirits.
You could shave the head with a sheet of glass or marble with some fine grit emery attached to it with 3 adhesive spray or spray contact adhesive. Move the head around in figure of 8 shapes until you have shaved the desired.amount.
Solidshot
Two options:
Ive definatly seen a video on youtube of this kid that shaved the head down using a bench sander, i tried to find the video but i couldnt. Also the oil thats in there has possibly been in for atleast 2-4 years. The guy i got the kart from said that they had been sitting in his garage for about 4 years and only really got a good run just over a year ago. You reckon i should take the whole thing apart and clean it properly and then put some new correct oil in?
If you're really worried, drain the oil, fill it with the correct oil, run the engine for about 20 - 30 minutes, drain it again & fill with new oil.
This procedure is most often done as a run-in. It gives the oil a chance to collect any impurities from around the engine.
Found it! Is this a yay or nay?
If you know what you're doing, it's a possible yay but, there's still room for error like taking more off one end/side than the other making the head uneven
Solidshot
Well none of this will be happening for a while now! I was out in the garden just now, started it up, propped it up on some axel stands and gave it full throttle for not even ten seconds, engine cut right out! go to start it again, pull the cord, stiff as hell! So im figuring that either its just had it? Maybe even a rebuild? Ive found a replacement engine cheap enough, so im going to get that in the next couple of days, put that on the kart for now and then rip apart the original engine and possibly rebuild it, if i can get it working well again ill do all the above mods! If not ill sell the kart with the new engine and use all the money to possibly buy a new project. Unless anyone has any ideas what the problem might actually be?
GAH! Im P!$$£D!
Nodroz
Belgium (Europe)
Your engine is probably sized now. The piston expends faster due to heat then the cilinder wall. If you instantly run at full throttle, the piston can expand that fast, so it gets stuck...
Another possibility is, that you were running with bad or no oil. If the moving parts of the engine doesn't get any lubrication, they'll break very fast.
Take off the head and look at the walls. Are they in good condition? No scratches etc?
Are you sure the piston is locked up there?
Solidshot
So assuming that it is seized, is it repairable? Or am I looking at spending more then it would cost to get a new engine? Also there doesn't I just checked and there doesn't appear to be a governor? But not entirely sure? So I'm thinking I might jus tear it all down and rebuild it, possibly modify it, but that's dependant on weather I can get it working again or not. It terms of the piston seizing if I let it cool down reckon it will start again?
