get drive from gx620 honda
buggyboss
scotland
Higuys. Just got the engine but has no sprocket on crankshaft? 1inch shaft with notch in shaft. Does the vtwin eng need belt pulleys then sprocket then rear axle sprocket?or can I just put sprocket on my vtwin shaft then straight to rear sprocket ?the guy that sold me this said its got a gbox onit I just need to put sprocket on crankshaft n away I go but am not sure???????thanks.
Any help wld b great guys
buggyboss
scotland
can anyone help?gx620
Need some tips on this type o engine vtwin. Do I need a comet 40 tc?or jackshaft setup?or change rear sprocket to a pulley. N jst b belt driven? Can I just put sprocket on crankshaft ?? thanks
buggyboss
scotland
Thanks. Wld a 40comet do job or wld a need to get a super expensive 1. And is this eng more hassl than its worth?????twin better than single tin???
buggyboss
scotland
Thanks a lot guys. Also what the best oil to use in my engine? Av found converter calld gtc with a 1inch bore full kit for 180£ ??
buggyboss
scotland
Thanks. Nice trike. What about oil will a gd 10/40 do it?think I just need battery n tc and its a runner. Want to get drive setup sorted then mod the chassis n powdercoat. Gonna put front suspension on it not bother about rear just put shocks on seat subframe ....
does not having a thicker oil in cold weather like up in scotland where it gets butt a** cold need to use a thinner oil for easier starts like using a synthetic 10w 40 that naturally thins out better
If you look at the manual you will see that SAE 1OW-30 covers all temperature ratings from about -5 deg C
