German motor clutch size
svince1884
I'm stationed in Germany and looking to replace the motor on my kids Murray Kart. Having issues though figuring out what size clutch is going to work. Not so much how much HP the clutch can hold but what is the keyway size. Can anybody take a look at this link and tell me. If using Google Chrome you can translate. That's what I do. Any help would be appreciated. Thanks.
Motor:
http://www.ebay.de/itm/121305698932?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
There are some clutches for sale on ebay.de but I don't know which one to buy.
Axx3d
MN
google translator said:
output of cylindrical shaft with keyway D: 25 mm, length: 88, 2 mm (see drawing) type 1-cylinder 4-stroke petrol engine air cooled displacement 270 of CC bore / stroke 77 / 58 mm power at 3000 rpm Max 5.97 (8,12 kW), kont. 5.07 kW (6.89) HP at 3600 RPM max 6.56 (8.92 kW), kont. 5.52 (7.51 kW) power take-off acting on crankshaft rotation the screw counterclockwise (see dimensional drawing) speed controller of mechanical centrifugal Governor to throttle cooling system forced air cooling with fan and air control system unleaded fuel super / normal fuel consumption at full load
The output shaft looks to be 25mm.. which is .98"...
You using a clutch or a torque convert?
well OR look at the pic the seller included ;)
Russ2251
AZUSA:Powered by LAWN-BOY
25MM is .9845. Unbelievably close to 63/64ths or .984375.
I routinely fit 1" bore clutches to 63/64ths (or 26mm) shafts by incorporating .007" shim stock in assembly of clutch to PTO. A perfect fit.
If you attempt to fit clutch without shim stock, it will not center.
I can supply a pic later this evening if interested in seeing how this goes together.
Addendum:
The bottom half of a ¼" key will have to be modified (filed) slightly to fit PTO keyway.
well, if you don't have the engine already, get a Rotek 13HP engine..
it's available in both 25mm and 1" shaft diameter.. and it's much easier to find a 1" clutch..
you still have to order the clutch in the US (for some reason OMB is cheaper than any european shop I've found) but at least it's easy to find ;)
the rotak 13hp is a bit more expensive.. but the Lifan here is not:
http://www.ebay.de/itm/LIFAN-188-Be...eile_Zubehör_Baumaschinen&hash=item5668172cea
As I said.. I ordered mine @ OMBwarehouse;
(added precision to my prev. post ;))
much cheaper incl shipping than any clutch I've found in europe.
the only other option for me would be a UK based seller on ebay "uk kart store"
he sometimes has clutches for 50€ incl shipping.
but 3/4" not 1" AFAIK.
