karl
This is my guide for getting an 4 STROKE engine to run. There are tons of threads saying my engine won't start so do these steps first.
If your engine won't start do these steps.
1. Check for spark.
2. Clean or replace spark plug.
3. Unplug kill-switch
If it still won't start
1. Try a shot of gas in the carb
2. Disassemble the carb and clean it with carb cleaner or kerosene.
1.Check compression.
If compression is low, It is usually because
1. Scored piston
2. Worn piston rings
3. Valves not sealing
4. Stuck valve
To solve these,
Scored piston= Top end rebuild, usually not worth it.
Worn Piston rings= Replace the rings and maybe hone the cylinder.
Valves not sealing= Lap the valves
Stuck valve= Tap down Valve with a mallet and use alot of oil.
That should get most engines started again.
This is a basic guide, so try this before you post a thread saying my engine won't start.
1. Check for spark.
1. Scored piston
4. Stuck valve
To solve these,
