Gem car super kart clutch help
GEM4SPEED
NH
Hello my name is Chris and I am new to the go kart world, but not to engines and autos. I need help picking a clutch and sprocket for my project .. This is what I have a electric gem car that I am turning into a gas job.. The gem car is a 2 seater weight is around 1200lb I know that's a lot, it was 1600 with the batterys. I am installing a yamaha 440 into it. This engine has a 1" shaft and not tappered. Clutch in the pic is the old one from the sled, can not use. need a gokart centrifical and sprock. The front diff has a 5:1 gears , Wheels are 165/70r12 . What I am looking for is a strong on/off road rig with good low end torque. Not super worried about max speed 40mph would be good. The engine is making around 15-20hp
I hate to tell you that,
but a centrifugal clutch will be a huge PITA with a thing like that.
Do yourself a favour and get a matching Torque Converter, it's more than worth it.
if you have use the driven that's maybe still on the sled and find yourself a belt for it.
(that's the best option) if it's not.. try to find the driven from a similar sled,
and if that too fails.. get a comet but a 94C or 103 I'd say.
to be honest I doubt it's just 20Hp it's closer to 40 IIRC. (well if it's a Rotax 440 we're talking about)
that means you'd need a very hefty TC and that's going to be expensive!
GEM4SPEED
NH
Yes 1" shaft and the sled clutch are to big. Will not mount down on the diff... Really want a centrifical clutch. Might think about a torque converter. Anyone have a link to one thAt will work.. So I can look it over
Fabroman gave you a link. It won't work if the engine pushes out 40HP though. No centrifugal clutch will
GEM4SPEED
NH
Looked over the link, I like the clutch but do they make one that can handle 20hp and think I need like a 4500 rpm engagem very big kart
GEM4SPEED
NH
Thats a funny language...[/QUOTE]
sprocket sorry :auto:
ALSO I WAS WRONG ON THE ENGINE IT IS A 340 NOT A 440
Ah, that makes a difference, your numbers make more sense now...
4500rpm engagement speed sounds a bit high...
If a clutch can handle 50hp, it will definitely handle 20hp; I don't understand the problem :huh:
GEM4SPEED
NH
Ok think I am going with the enforcer clutch. Now just need help picking the sprocket..
Ok, we have the reduction ratio of the diff but, what we still need is:
-tyre diameter, from ground to top of tyre
-number of teeth on the clutch
Now, based on the tyre size you provided, I'm estimating tyre height to be around 21"; using that number, you need a total 8:1 ratio to achieve 40mph@5000 engine rpm but, will that provide enough torque?
