gears?
Micketr
i want to get alot of speed...;
sssssoooooo what would hapen if i put a big gear as the driver to a small gear like a 1/2 gear ratio???????????????
Jcotz
...wasn't there
NY
Your clutch would immediately burn out and you would not move. If you got some sort of running start, then potentially you could get anywhere. Either way it is totally impractical.
Micketr
k thanks, but what do i do than to get the fastest speed, ive watched videos on gear ratio.....(count the teeth and put as fration),but i dont get any of it if you could help me out or link me to somewhere.. greatly appriciated
fowler
Bullsbrook West Aus
Post your engine hp and rmp
The kart weight with u in it
The rear tyre diameter
And the type of driving u will do as in sand, mud, bitumum and so on
Micketr
this is for a bike
49cc pocket bike engine,12000rpms i think
16" tires
on road
thanks
Due to the tiny engines in these bikes, it may be close to it's peak speed gearing already. You can try installing a rear sprocket that has a few less teeth on it, but be aware that the clutch may not be able to tolerate much more load and burn out, or the engine just won't have the torque to get you there.
Jcotz
...wasn't there
NY
I agree with toy-story, you probably won't be able able to get much more speed with your current engine.
Realfast89gt-It's a lotus not sure what model, I took the picture myself at a racetrack.
I agree with all the above. Your engine is small, and gearing higher is going to be a problem for you. You also have 16" tyres, which are freaky big for the size engine that you have. Get smaller wheels if you want to go a bit faster
Post your sprocket tooth counts as well, there is not much we can tell you without those
dmaznic
dmaznic
Toronto
if you feel it takes forever to get top speed, get a LARGER driven sprocket
if you feel it gets top speed very easily, get a SMALLER driven sprocket
until it feels "just right", there is always room to improve the top speed. If you really want, just go downhill with a tiny sprocket :D
12000rpm really?
Jcotz
...wasn't there
NY
dmaznic-
Some of those small 2-stroke pocket bike engines probably rev pretty high. To 12,000 Rpm's? Maybe not, but probably over 5,000. Correct me if I'm wrong.
