Gearing
😑....off road kart, race kart? Base line is generally 6:1, 10 tooth on the engine side, 60 on the axle. Also depends on tire size, kart weight with driver.
Kadin163
I want a street kart... From the bottom of the tire to top of tire is 8.10 inches and the kart with the driver is 325lbs
that'd be a 11" wheel (3.5 sidewall times two is 7, plus 4" for the rim = 11" nominal diameter)
6:1 ratio is golden,
you could get away with 5:1 ratio (in case you do not intend to climb steep inclinations)
And gearing lower than 7:1 might get you into clearance issues with the rear sprockets even with #35 chain so you'd need a jackshaft.
