RageKage76
- Messages
- 8
- Reaction score
- 0
Would I be able to use a 10 tooth centrifugal cluch with a 25 tooth sprocket on the axle?
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 10 in | 25.4 cm[/B]
[I]Total weight[/I]: [B] 363.76 lbs | 165 kg[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Original HP[/I]: [B] 7[/B]
[I]Asummed HP[/I]: [B] ~7[/B]
[I]Torque[/I]: [B] 10.21 ft lbf | 13.85 Nm[/B]
[I]RPM[/I]: [B] 3600[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B]
[INDENT][I]Final ratio[/I]: [B] 5:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Max Wheel Torque[/I]: [B] 51.08 ft lbf | 69.25 Nm[/B]
[I]Acceleration[/I]: [B] 10.83 ft/s² | 3.3 m/s²[/B]
[I]Top Speed[/I]: [B] 21.42 mph | 34.47 km/h[/B]
[/INDENT]
[B][U]PROBLEMS[/U][/B]
[INDENT][B]You might burn your clutch/belt![/B]
[B]Gear ratio too high![/B]
[I]Suggested final ratio[/I]: [B] at least 6.1:1[/B]
[/INDENT]
[/FONT]
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 25.4 cm | 10 in[/B]
[I]Total weight[/I]: [B] 165 kg | 363.76 lbs[/B]
[/INDENT]
[I]Torque[/I]: [B] 13.85 Nm | 10.21 ft lbf[/B]
[/INDENT]
[INDENT][I]Final ratio[/I]: [B] 4:1[/B]
[I]TC type[/I]: [B] series 30 6" driven[/B]
[I]Lowest ratio[/I]: [B] 10.8:1[/B]
[I]Highest ratio[/I]: [B] 3.6:1[/B]
[/INDENT]
[INDENT][I]Max Wheel Torque[/I]: [B] 149.58 Nm | 110.32 ft lbf[/B]
[I]Min Wheel Torque[/I]: [B] 49.86 Nm | 36.77 ft lbf[/B]
[I]Acceleration[/I]: [B] 4.05 m/s² | 13.29 ft/s²[/B]
[I]Top Speed[/I]: [B] 47.88 km/h | 29.75 mph[/B]
[/INDENT]
[/FONT]
