gearing
Herman
I'm switching from a torque clutch to centrigal clutch. I am running a 45 tooth on the axle. What should I run on the cent. cluch. Using a 5 hp motor and 18 inch tires on the back. Also its a yerf dog
anderkart
Surprise Arizona USA
What model Yerf Dog kart do you have? (try to post some pics so we can give you better advice)
Whats wrong with your old torque converter? You should probably just repair it.
Here's some good info on how to do that. Just click here:--> http://www.diygokarts.com/vb/showthread.php?t=7332
__________
With a centrifugal clutch conversion on a heavy off-road kart with tall tires, you'll probably need the smallest tooth count gear on your clutch you can find.
And then you will probably also need to install the largest axle sprocket you can find to hopefully end up with adequate torque/acceleration for off-road - hill climbing ability.
With your 18" tall rear tires on a heavy off-road kart, you really should use a torque converter, or at least use a jackshaft setup if a centrifugal clutch is used. Otherwise those tall tires will be causing your final drive ratio to be putting a major strain on your centrifugal clutch.
If you do decide to try a centrifugal clutch without a jackshaft, I think you might have problems with one of those cheapo $35 to $50 models.
I'd suggest you get the highest quality clutch available like the Noram "Arena" 3/4" bore clutch model with 9 teeth like this:--> http://www.out2win.com/catalog/noram.html#arena
Or to try and save some $$$, one of these might hold up:--> http://www.out2win.com/catalog/noram_ge.html
If you used a centrifugal clutch with a jackshaft setup, (similar these pics below) you could select your jackshaft gear sizes to end up working fine with most any inexpensive clutch model and/or sprocket sizes:
Herman
It's a yerf dog 3020. The torque converter will get stuck in the open position and won't close causing the motor to die when you apply the brake.
anderkart
Herman, you would be much better off repairing your torque converter problem, or if necessary replacing just the parts of your old torque converter that are malfunctioning, Or even installing a whole new torque converter. A centrifugal clutch just wont work as well as a torque converter on your kart.
Here's a link to some really good info you need to know.
Click here on this link:-->http://www.diygokarts.com/vb/showthread.php?t=7332
(everything below is a quote from that thread:
Blazkowiez
Kart Aficionado Join Date: Feb 2010
Maintaining Your Torque Converter
I started to write this for Hybrid, but felt I should continue to make this easier to find. Couldn't find this posted by others.
1. Removal - You must first remove the drive clutch from engine, the bolt will be on the output shaft of the motor, you'll need an impact wrench or a box end wrench and another to tap the box end using blunt force to remove the bolt. Once you have the bolt out it should come right off the shaft easily aside from any rust that keeps it on the shaft. Grease the shaft slightly with no clutch on there to make removal easier in the future.
2. Disassembly - Place the clutch assembly on a work bench or table and remove the outer cover, keep notice that the hub in the assembly has the flat side down and the molded side up which will fit exactly in the cover. Remove the hub, set it aside. Remove the bronze bushing off the backplate and set that to the side. Remove the spring pack assembly if you have not checked it recently for wear, if this is hard to remove try wedging a flat blade screwdriver for ease.
3. Analysis - See if the clutch is in good shape, the main part of the drive clutch will have an aluminum spring pack assembly which has 2 springs which when removed should spring out straight when unhooked and both pins should be firmly inside the aluminum. If either of those are wrong you may need to replace something. Check the bronze bushing for a crack where it may have broken. In the main assembly and the hub, check side to side play, this should be a fairly firm fit, it should not have much room to wiggle left and right, a large amount of play will indicate the clutch is heavily worn from use and may need to be retired. As with most things, if you notice wobble in the clutches, this is sometime repairable but usually is the kiss of death.
4. Cleaning - The hub needs to be cleaned, the best tool for this is a wire wheel on a bench grinder, clean the hub of any material. Next take a wire brush and brush out the splines in the main assembly and make sure it is nice and free of debris, it may need a rat tail file the very first time you do this, we use a diamond bit chainsaw sharpener for fine cleaning. The sides of the clutches which the belt rides on need to be cleaned to where there is no rust or pitting, it needs to be smooth. Start with a wire wheel and if severely rusted you may move to a sand paper, we use a pneumatic 3M sanding wheel to clean these when in bad shape. When cleaning the hub and main assembly that hub should be able to drop clean through the assembly into the palm of your hand with no problems. If it does not do so, it is not clean enough.
5. Re-Assembly - Place the spring pack assembly back into the main portion of the drive clutch, this should be flat side down, angled side up. If you have trouble placing this back in the assembly you may need that flat blade screwdriver, we also take use of a 4x4 as wood will not damage the assembly if you need to smack it into place. Place the bronze bushing back onto the back plate, place the hub, ridged side up back into the main part of the assembly.
6. Lubrication - This is a dry assembly, no wet lubrication PERIOD. The only part that would need lubrication would be the inner side of the outer cover on the main assembly where the aluminum piece rides on it using centrifugal force. The lubrication in question suggested by Comet is their own brand of dry lube, which is a dry moly blend, I'm sure there are other fine companies out there that offer this, but it doesnt need lubrication often, its not that big of a deal, the main thing you need to focus on is cleaning the clutch. Any wet lubrication you do put in this will create a terrible snowball effect which will collect more dirt, dust, belt fiber, debris, etc. Bad idea to use wet lube.
7. Re-Installation - Put the clutch back on your kart, backplate first with the bronze bushing, then the main portion of the drive clutch beveled side first, outer plate away from the engine etc. Screw the bolt, lock washer, and flat washer back on the kart, if you have an impact wrench this is the time to use it, if not use a box end wrench and pull the recoil to lock up the washer and keep the bolt firmly in place.
Maintenance - Comet did suggest you clean this every 5 hours of use, but if you ride in the sand or an excessively dirty area, I'd say you need to make this part of what you do following riding during the clean up and maintenance time you put into keeping your kart in good shape.
*Driven Clutch - The larger clutch on the jack-shaft assembly of the kart is considered your driven clutch while your drive clutch is the one on the motor. Primarily cleaning this is just spraying the assembly with brake cleaner and making sure the surfaces where your belt will ride are clean, you might not want to be so hasty to disassemble this clutch given it is spring loaded and must be wound back into place correctly or it will not operate at peak efficiency. This is not for beginners. An easier route to clean this would be to use the fact that it can expand as it does when in operation, pull it apart and drop a nut or something inside the clutch so that you can have it apart while sanding for ease. Simply remove the nut when done.
**Series 40 Torque Converters. Those of you who have series 40/44 Torque Converters have a much easier process for maintenance. If there is a demand we can go over that process though it is very very easy.
This next section is as integral to operation as it is to keep your clutch clean, you must have the proper belt for your clutch and set-up.
If this chart is not self explanatory first determine what sort of assembly you have. If this is a series 20 you will have a symmetrical system where the angles on the clutches will be identical. If you have a series 30, you will have an a-symmetrical system where the back plate is nearly flat, the main assembly will be angled. The next thing we must determine is that your driven clutch (on the jack-shaft) is 6 or 7" in diameter. The final thing you must measure is the full distance center point to center point between the clutches. Do not round the distance, keep it exact to the 1/16th of an inch, this really does matter.
With Comet no longer in production to supply belts you sometimes must make due with the belts given distances, for those of you with Carter karts you may have to make due with 203581,203582, or 203583 given you can adjust your assembly. When you are able to adjust there is more power. Some are more lucky than others, those of you with stock assemblies on the Torq-A-Verter backplate, those with Yerf-Dogs or Mancos, all of these still have the 2 belts in production from alternate sources, the 203591 and 203589 belts are still here to stay for now...In other words, if this is not you, take what you can get
Should your belt be too lose or worn too heavily your kart will be sluggish and preform terribly. Alternatively, if your belt is too tight it will not disengage and occasionally snap the belt immediately.
Lastly, those of you with MaxTorque Torque Converters, PM me and I'll help you cross reference your belt number to the corresponding Comet Series 20 belt. The cleaning process will be the same for you.
I can add pictures later if my descriptions are terrible or someone feels it necessary.
redsox985
PA
That kart will most likely smoke a cent. clutch unless it's geared for LOW speeds. Post some pictures of your TC if you can't figure it out.
Herman
I fixed the torque converter. Wow this thing has power. Thanks everone....
Herman
I ordered a new belt, sanded all the pids and scratches out of the converter, bent the bars in the clutch unit and lubed the entire unit.The new belt made the biggest difference. It has not got stuck open as of yet. I also purchase a replacement motor from harbor freight(6.5 on clearance for 74.97) that I'm keeping as back up in case the honda 5.0 ever fails or I want to increase the power.
Herman
will I see a difference in the power or speed by changing over to the 6.5 motor?
