thebroketeenager
Hey guys, some money is soon going to fall into my hands (thanks eighth grade graduation gifts
) and I want to replace my boat anchor of a 15+ year old GX200 with a new Predator 212. Problem is that since this old engine is that it uses the factory available 2:1 gear reducer with a wet clutch. (It also rod knocks, burns oil, has WAY too much blow by, and bad valves.
) In addition, it is belt drive so I can't reuse sprockets, which bring me to my delima.
I don't know how exactly to gear this thing. Im using a 12T clutch and 11 inch tires I want to have a top speed of 20-30 mph governed. I don't know if that's possible without bluing the clutch pads immediately. Right now the only sprockets I can get are 40T, 54T, and 60T. According to a speed calculator I found, ill go 26 mph with the 54 tooth.Any help would be greatly appreciated.
Again, the specs
Stock: (as I have it)
GX200
2:1 reducer which makes rpm at the pinion 1800
pinion cog: ~20T
spur cog: 64T
11 inch tires
250lbs with me on it
used on flat ground
As I want it:
212 Predator
12T clutch
54T(?) sprocket
Clutch:http://www.affordablegokarts.com/mm...Code=A&Product_Code=SMFKC**&Category_Code=PCJ
Sprockets:http://www.gokartsupply.com/sprocket.htm (The ones with the 5 1/4" bolt pattern)
I don't know how exactly to gear this thing. Im using a 12T clutch and 11 inch tires I want to have a top speed of 20-30 mph governed. I don't know if that's possible without bluing the clutch pads immediately. Right now the only sprockets I can get are 40T, 54T, and 60T. According to a speed calculator I found, ill go 26 mph with the 54 tooth.Any help would be greatly appreciated.Again, the specs
GX200
pinion cog: ~20T
spur cog: 64T
11 inch tires
used on flat ground
As I want it:
212 Predator
12T clutch
54T(?) sprocket
Thanks for the thought though!
Affordable go karts or AGK is a great website. Lots of parts, Good how tos, and calculators. Bookmarked as well
