Cutters
Hi all, I'm new to karting and need a little help with my new project. I've recently built a new kart for my kids and i'm up to the gearing part.
I'm using a Honda GX270 (9hp)it has a 6:1 reduction box built in with no clutch and has a 1" output shaft. My axle set up is a 30mm diameter and set up to be a single wheel drive. I'm not after top end speed, as my kids are still young. My rear tyre Diameter is 16".
I was planning on going from my engine to a jack shaft to bring the rev's back up (1:6) then i will fit a max torque 12 tooth #35 pitch to jack shaft and run a 76tooth #35 pitch sprocket on the axle. this would leave me with a drive ratio of 6.3:1
So i guess my question is will this work, without over loading my clutch. Im not at all worried about top speed.the kart will mainley be used in a yard with very little hills...
Any help would be appricated..thank you
