r_chez_08
Should be in the shop...
This is a fairly newbish question, but I would like some honest opinions of what would be best-
My kart has 19" wheels, 54t rear and 9t j/s, with a comet 40. I am running a 6.5hp clone, which should be running around 11hp hopefully, reading on bobs 4 cycle (I will make another thread about my clone build)
I have ordered an aluminium flywheel and have a billet rod for the motor. I want to take advantage of my extra RPM, and will run 18lb springs. After all, I have probably lost a little bottom end, and so may mod my 40 series to engage a bit higher.
@6k my kart is geared for 56mph. Not only do I not want to die, I also do not know if my kart would make it that fast. Oh and I would probably poop myself! I would rather tyre spinning torque. Also, before mods my clone did not pull me up hills at satisfactory speed. I think 40mph should be plenty realistically.
I can make up an 8t sprocket to fit my 3/4" j/s at a push. that would put me at 50mph @6k. Still pretty fast
Should I import a 60t sprocket from USA and get an 8t sprocket for my j/s, putting me @ 7.5:1 or 45mph @ 6k? I don't want to install another jackshaft, because it would probably take me like 6 months and cost more than the above sprockets. A 60t sprocket would have approx a 10" diameter, leaving me with 4.5" ground clearance (probably plenty)
Thanks, I just thought I should probably get the neccesary parts before I put it back together. I would really like to use my extra revs cos they cost me £70 for the safety bits (f/w and rod)
Cheers
Cheers
