Gearing for 13hp
Will
New Zealand, Auckland
Hi guys
Do I am getting a Honda clone 13hp the only gear setup I can use is a 10 tooth to a 48 tooth. I weigh 60 and the kart weighs around 100 kg, I am using a centrifugal clutch
So my question is would this gear ratio work for off road ?
Cheers
Will
Hi guys
Cheers
Will
Definately NOT!! You have a 4.8:1 gear ratio, and I am assuming large diameter tyres as well. You will burn that clutch out in a few seconds. The only way you are going to get ANY performance out of that clutch and kart is if you gear it MUCH lower. You are going to have to get at least a 72T sprocket, and even then you are not guaranteed a good offroad ride.
The best would be to get a Comet 40 series (yes, I know they are expensive). A centrifugal clutch is not made for offroading use.
You are going to have to come up with some other options, because what you have now won't work.
Sorry to rain on your parade, but I just don't want you to sink money into something that is not going to work
Will
Thanks for the reply,
Yeah the wheels are 40cm :oops:
So what's around the largest sprocket size before it touches the ground haha
Like reasonably
Cheers
Like reasonably
Cheers
You can have a look at THIS table. It gives sizes for tooth counts. I am assuming it is a #40 chain. I think you can run approx 90T sprocket with 40cm (15.74") tyres
You could use a jackshaft to gear down without huge sprockets. A jackshaft will use a combination of smaller sprockets to give you compound gear reduction.
KartFab
Dallas, TX
I don't want to step on anyone's toes, but I will give you some good information on the gearing you need for your tire size with a 40 series torque converter.
1) Landuse is correct about the centrifugal clutch, and gear ratio, but that is not the whole picture.
Tire size plays a HUGE impact on the actual torque and load an engine experiences in addition to the gearing. As you go up in HP on a 4 stroke engine, you have more wiggle room because they are just so powerful at lower rpms compared to the 5 or 6 hp engines that would stall at these gear ratios.With that said, here is some advice:
If you are going to buy a torque converter, KEEP YOUR SPROCKET In fact, you can keep your 48 tooth sprocket and actually go up to an 11 tooth sprocket on the jackshaft with no problems at all. Here is why:
I have a kart with 22" tires, and a 6:1 gear ratio, the top speed is 39 mph, 13 hp engine. This came 'stock' with that gearing and tires with an 11 hp engine that i replaced with a 13 hp engine. Because your tires are so much smaller, I used my magical spreadsheet that calculates load on the engine, gear ratios etc and found out that with your 48 tooth sprocket, 15.748" tires, and a 11 tooth jackshaft sprocket, you will have about the same load on your engine as my kart, and go 38.6 mph.
10 tooth jackshaft sprocket will get you going 35.1 mph top speed, but will give you more torque than you need (which isnt really a bad thing if you like peeling out everywhere)
Either a 10 or 11 tooth jackshaft sprocket will work just fine with thos 40 cm tires, a 48 tooth axle sprocket, 13 hp engine, and 40 series torque converter
Have fun!
(these calculations were done assuming the driven unit is the standard 7 1/2" driven unit on a 40 series torque converter)
Will
Thank you so much guys, I really do appreciate it.
So now just to get a tc in nz,
I will be starting my build in jan and will post pics and ask for advice
:D
Cheers
