I don't want to step on anyone's toes, but I will give you some good information on the gearing you need for your tire size with a 40 series torque converter.
1) Landuse is correct about the centrifugal clutch, and gear ratio, but that is not the whole picture.
Tire size plays a HUGE impact on the actual torque and load an engine experiences in addition to the gearing. As you go up in HP on a 4 stroke engine, you have more wiggle room because they are just so powerful at lower rpms compared to the 5 or 6 hp engines that would stall at these gear ratios.With that said, here is some advice:
If you are going to buy a torque converter, KEEP YOUR SPROCKET In fact, you can keep your 48 tooth sprocket and actually go up to an 11 tooth sprocket on the jackshaft with no problems at all. Here is why:
I have a kart with 22" tires, and a 6:1 gear ratio, the top speed is 39 mph, 13 hp engine. This came 'stock' with that gearing and tires with an 11 hp engine that i replaced with a 13 hp engine. Because your tires are so much smaller, I used my magical spreadsheet that calculates load on the engine, gear ratios etc and found out that with your 48 tooth sprocket, 15.748" tires, and a 11 tooth jackshaft sprocket, you will have about the same load on your engine as my kart, and go 38.6 mph.
10 tooth jackshaft sprocket will get you going 35.1 mph top speed, but will give you more torque than you need (which isnt really a bad thing if you like peeling out everywhere)
Either a 10 or 11 tooth jackshaft sprocket will work just fine with thos 40 cm tires, a 48 tooth axle sprocket, 13 hp engine, and 40 series torque converter
Have fun!
(these calculations were done assuming the driven unit is the standard 7 1/2" driven unit on a 40 series torque converter)
