gear ratio
mpyrol
I have acquired an old Murray explorer kart. It has large rear tires, specs say 17.4 diameter. the motor will have clutch to sprocket chain drive. I see these karts with belts and pulleys but this was not on this model or has been removed. I would like suggestions on what type of gear ratio and clutch/chain/sprocket size would be appropriate for this scenario? For an idea about power I plan to start with a clone engine. I saw a engine marketed as titan. A predator motor may be what I choose. I am probably not going to invest in an animal. I don't want to race but I want it to be fast enough to be fun. any input is appreciated.
Hi and welcome.
forget about using only a centrifugal clutch!
Buy a torque converter, (the belt pulley system) you still need chain and sprockets, but your gearing and speed will be much nicer ;)
PS Post pics of what you have and we can point you to what you need
mpyrol
I have attached pics of Kart. Is a jack shaft required? I think this kart had one originally, but I can't be sure. The position of the axle sprocket would be ahead of the Torque converter. Should I do smaller tires? Any input would be appreciated.
qtband
St. Louis, MO
Doesn't matter if it's in front or behind as long as you can line it up. Looks like you can move the sprocket on the axle to help line things up. Get a 212 Predator and a torque converter and you will be a happy karter! Leave the tires.
great!
Yes, you do need a jackshaft, NO you do not need to care at all.
since you're going for a clone (I think 6.5hp clones like a 212 predator or 200cc lifan gx200 cone or alike)
you could just buy a TAV2 kit on ebay (chines clone of the comet series 30 TAV2 kit)
it comes with a nice backplate that conveniently holds a jackshaft where the driven sits on.
around'ish 80bucks well spent IMHO.
with that installed, your sprocket looks to have the perfect size already (without trying to extrapolate toothcount just seeing it's size ;))
Measure the pitch of the chain (i.e. from one rivet to the next)
if it's 172" you need to buy a TAVKIT with a #40 sprocket if it's 3/8" you need the #35 sprocket with the TAVkit.
a 212/200 clone usually has a 3/4" shaft..
for the driver bore you need to get one of those (most common size actually)
so be careful about those numbers, and when in doubt ask again :D
new chain, some rust removal and you'll be up and running in no time.
