gear ratio with TC help
rickou812
North Florida - Tri-State Area
Howdy,
I just finished up a coleman ct200u build. I placed a moded hemi 212 on it with a 30 series torque converter., 6" driven.
Engine mods include:
+.020 Billet rod
Billet flywheel set at 32 degrees
Ported and polished hemi head
SS valves 28/24mm
26lb springs
F275 cam
CM pushrods
.675 bored carb.
Governor removed..etc..
The coleman has a 19" wheel
and running a 10t to 50t sprocket using a 6"driven 30 series.
I would think the engine would turn 6000-6500 pretty easily.
What would the drive ratio work out to with this combo?
What should the top speed be?
The stock ratio was 10:1 and with the stock engine running approx. 5000 rpm, it would top out at 22mph.
Thanks,
Rick
let's see...
KartInfo by kartcalc.net:
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 19 in | 48.26 cm[/B]
[I]Total weight[/I]: [B] 330.69 lbs | 150 kg[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Original HP[/I]: [B] 12[/B]
[I]Asummed HP[/I]: [B] ~12.78[/B]
[I]Torque[/I]: [B] 17.51 ft lbf | 23.74 Nm[/B]
[I]RPM[/I]: [B] 6500[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B]
[INDENT][I]Final ratio[/I]: [B] 5:1[/B]
[I]TC type[/I]: [B]  series 30 6" driven[/B]
[I]Lowest ratio[/I]: [B] 13.5:1[/B]
[I]Highest ratio[/I]: [B] 4.5:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Max Wheel Torque[/I]: [B] 236.38 ft lbf | 320.49 Nm[/B]
[I]Min Wheel Torque[/I]: [B] 78.79 ft lbf | 106.83 Nm[/B]
[I]Acceleration[/I]: [B] 16.5 ft/s² | 5.03 m/s²[/B]
[I]Top Speed[/I]: [B] 81.65 mph | 131.4 km/h[/B]
[/INDENT]
[B][U]PROBLEMS[/U][/B]
[INDENT][B]Max-speed cannot be reached![/B]
[I]Max Speed[/I]: [B] 68.2 mph achievable | 109.76 km/h[/B]
[B]Gear ratio too high![/B]
[I]Suggested final ratio[/I]: [B] at least 5.99:1[/B]
[/INDENT]
[/FONT]
hmmm I might be mistaking the power you might push with your mods.. but 13 horses seem plausible..
so upwards of 70mph (IF you reach those rpms) (~75 for 6k rpm)
(the warning estimates a gokart and it's windresistance, that's why it moans about 68mph... ;))
weight might be an issue so I took a number from higher up the shelf, not knowing your real world value.
frankly.. upwards of 60mph windresistance is your biggest issue already not talking about the security issues running those speeds on a chinese mini bike ;)
Anyways, it'll be hard to guess since the torque of your engine is now a complete mystery...
and can only be guestimated...
Again, if you have the torque and thus power to reach those rpms.. mathematically you might hit 75 to 80mph.
rickou812
Thanks 'sid. Looks like it may like a 70t sprocket and wheelie bars...
I tested it out today a little, and it was fun.. Kinda of tough to keep the front wheel on the ground, but it doesn't have enough torque to pull into high. It tops out about 42mph, but seems to stall at about 4800rpm.
KartFab
Dallas, TX
Problem is the torque converter. Get a clutch and you will be able to rev higher. (Or so I've been told).
torque converters are great but they loose 20% of power by design
(the belt is constantly slipping in all pulley setups.. like the TC)
and that's 20% in torque mostly (means loss is all over the rev band),
chances are you'd indeed get better results with a slightly lower gearing and a clutch.
since a chain will be nearly 100% effective in that regard.
just lowering the ratio would only give you even better acceleration, which by your description is already wheelrasing ;)
I think we could use a pic of your TC.. since frankly it should not be in low gear for any detecatable amount of time with a setup like yours...
(only if you start up at a very very steep hill maybe)
but instead snap into high gear instantly.
So there might be something wrong with it..
let's see, maybe we can help you fix that.
rickou812
I did a poor job in post #3 in describing. The TC is working perfectly. It is pulling into high. What I should of said was the engine does not have enough power to pull over what sounds like about 4800 - 5000 RPM in high, ear tach. It will run about 42mph by gps. I think power is being limited by the carb. It is a stock style carb bored .675 by ARC. It may be a little on the fat side too. I am not sure if I should try to dial this carb in or get a tilli 304 and run methanol.
The predator head has a 28mm intake valve, so I am confident the .675 carb is a limiting factor in higher RPM..
But don't get me wrong, overall the engine and bike is running great and is quite impressive. Just would like to see it pull to or over 6000 RPM. I think it is close, just got to work out the details.
Thoughts?
do a plug reading.. if your spark plug is black or at least very dark you're running your engine too rich and need to lean out a bit for best performance.
still.. it's a relatively small enigne, and chances are you do not have enough high end power
to crack the speed limit of ~60mph (that's what your 4800rpm should do frankly...)
42 on your gps are more like 3600 (in fact 3600rpm should equate to 45mph with your gear ratio)
all that assuming your TC is in good condition and you run a TC belt (not some automotive v belt we've seen here just recently causing the performance to drop below acceptable limits)
that's another reason we mainly ask for all sorts of pics, since every issue can have multiple causes, even once you're not aware of at first sight. (so let us have a second sight ;))
Anyways, dial in your carb properly and see how it does,
get a good speed reading to get a better guesstimation
make sure your gps accuracy is below 5m [roughly 15ft] but usually displayed in meters for sure less than 10meters and run for at least 400 meters at speed [~quarter mile]
that way your gps speed reading should be very close to your actual ground speed (within 0.3 mph/h or something)
42mph is off by quite a bit
(again if you haven't miscounted your sprocket teeth or have a faulty TC or incorrect belt or or or or or)
Bbqjoe
Banned
Location, Location
rickou812
All righty, it was definitely running rich. Which is surprising, it only had a 36 jet in it. I put the stock predator 212 jet in the .675 bored carb and made another couple of speed runs, picked up a bit to 46mph. Belt is definitely slipping. After the 46mph run, the TC was hot and a some belt smoke on shut down.
Here is a quick video of the TC after the rejet, but before I made the speed run. Please excuse the sideways video...
http://www.youtube.com/watch?v=3JCILOJocyQ
Sooo..
well that helps indeed..
the TC seems to work just as you said "perfectly"..
that's good,
a ton of belt dust on your backplate is not a good sign, I hope it's from a previous belt, not the current one!
if it is.... clean the sheaves (they must be perfectly smooth and -of course- clean, no oil, grease, dust or dirt...!)
otherwise you'll be buying belts on a weekly basis ;)
That being said.. that engine is running NOWHERE NEAR 5k rpms in the video .. really sounds like a governed engine from what i can tell (by my trusty *cough cough* ol' ear tach ;))
and that's with no load...
so either you've been not revving up (which is in fact a good idea w/o load being cautious not to blow it up for no reason) orrrrr which would be an issue and the reason you're not hitting the speed you'd assume... the engine is just not getting there.
And frankly, 5k can be done with an ungoverned stock engine .. so you might have tuned it down by mistake ;)
let's assume you've been cautious for now.
Belts always slip slightly (it's their design flaw) and thus they do get warm after a short amount of time.
Hard to tell what you consider hot, hard to tell if it just rubbed it's flanges in (new belts do that) or if it was indeed smoking because of an issue with the TC.
So yeah, back to TC maintenance for now I'm afraid.
clean sheaves and free of grease except for the inside of your driver (that could use some dry lube - DRY is an important part of the designation ;))
and once that's moved out of the way for good,
all that's left is to find out why your engine is not providing the power you'd expect.
to me it sounds a bit rough.. but most engines do (for me at least)
but you might want to check the ignition timing again sounds a tad too early
(again...'ear tach'...'over the internet'... 'random guy half way across the planet': take this with a grain of salt ;))
but IMHO, checking everything twice is much better than just assuming everything's how it should be and just move on ;)
rickou812
Unfortunately that is belt dust, and that was a a brand new belt.. less than 1 hour run time on it. It seems fine just normal riding, doesn't get hot etc.. but definitely does not like the sustained high RPM speed runs.
I thought about going back to the clutch, as suggested earlier, but when I plug in the specs in the kartcalc, it shows I would have a top speed of 34mph at 6000rpm. So I think for my purposes, the TC is still the best option with the understanding it will not stand up to sustained high RPM use. Plus I believe, and kartcalc agrees, that going to a 70t rear sprocket would make the TC much happier.
I noticed flyinhillbilly has a similar build and will continue to monitor his progress as he is still running a clutch, but has mentioned going to a TC at some point.
