SKEETER1978
Hello Im a newbie here so ill give a little info.
My name is Mike and i recently got my kids a old used kart with a 5hp briggs, I repainted it replaced some eng seals, carb seals, tires and brakes and got that that thing running good. (They love it).. so now i want to have fun too. So I got a used Haase corsa full size frame and a 1 1/4 axle and i am going to put a 160cc Suzuki atv motor with 5sp trans in it. This motor runs a 520 chain with a 11 tooth eng sprocket and i have the 39 tooth axle sprocket but i think 39t wont work, and im not sure if i can get a sprocket for the eng side in a diff tooth count or chain size? What would be the best rear sprocket size to run with this, I was thinking a 29-33.... there is not alot of info on the Suzuki eng out there i think it runs 6000-7000 rpms and im guessing 14-16hp (I will be running 11in slick tires)(I found that a Suzuki 125 makes 11.7hp at 7000rpm)
Any help will be appreciated
Mike
Mike
