aeriojunkie
- Messages
- 14
- Reaction score
- 0
Okay, so I am getting ready to build up the 2-seater rolling chassis that I just bought used for $50! I am trying to build it for my son and daughter to ride on, so I don't want it going too fast because of quite a few obstacles in the yard and I don't want them going too fast either. The kart has a jack shaft setup on it already. It has a 60 tooth sprocket on the axle going to a 12 tooth on the jack shaft. The other end of the jack shaft currently has a pulley, which I am going to change to a sprocket so that I can get a new clutch locally and inexpensively.
I know that I currently have a 5:1 ratio, which is pretty good all around ratio, but I want to slow it down more. I just don't want to set up something that just creeps around at the same speed as a powerwheels toy.
Now for my question. If I set up a ratio between the clutch and the jack shaft do I add the two ratios together or do I multiply them? for instance, would a 5:1 and a 2:1 create a 7:1 final ration or a 10:1 final ratio? Thanks in advance for all your input!
