Hi,
I could need some advise on gearing for my wheelbarrow hotrod
http://www.diygokarts.com/vb/showthread.php?t=38258
Data:
Engine: B&S Vanguard 6.5HP
Rear wheel diameter: 19"
Governed rpm: 3600
Torque converter TAV2
Estimated cart weight with driver: 300lbs
Rear axle ratio: 3.8:1
These numbers equate to a theoretical top speed of 54 mph, way too high for my application (kids kart)
I see that comet sells a device that can limit the travel of the torque converter and thereby reduce top speed. However I would never need this cart to go above say 30-35 mph so I am thinking I should reduce gearing further. I have the opportunity to introduce gear reduction between the torque converter sprocket on the driven pulley and what will be the drive shaft going to the rear axle. The sprocket on the TAV2 has 10 teeth and I could have a 15-16 tooth sprocket on the drive shaft. Top speed would then be 34-36 mph. I could also live with lower top speeds.
I guess what it comes down to what kind of gearing this kart would need to have decent acceleration with the 6.5hp engine (top speed being less important)?
:http://www.diygokarts.com/vb/showthread.php?t=38258
Data:
Governed rpm: 3600
