timmytim
Will a gasless welder get hot enough to weld up a go kart frame?
This pipe ure welding from lowes, are you building karts with it?I weld allot of that cheap house pipe (like at Lowes) thick walled, heavy black pipe and my wire feed has plenty of penetration with flux cored. My welder is a Hobart 175. I have thought about hooking up the gas kit for it but never have had the need or desire to buy a tank. I'm sure my welds would look better if I did though...
The 175 works better then the Lincoln 135 I had before it though, it didn’t seem like I was getting enough heat. The 175 will blast through a ¼ walled pipe with ease, lol. Found out the hard way when I first got it.
As far as cleaning the slag, I just use a twisted strand wire wheel. I use it to clean where I’m going to weld, and then clean the weld itself. Works like a champ.
I have, but it is heavy, very heavy. I built 2 go karts from it and 1 mini bike. I got the house pipe for free so I just used it, but if I was going to buy metal to build a new frame it wouldn't be house pipe. Don't get me wrong its easy to work with and weld, but just too darn heavy.
Its great for building fence gates and trellises for plants though, lol. very strong stuff.
