ghost civic
Ive been messing with a 2000ish john deere riding mower that I plan to make into a go kart.
The thing had sat for a year or 2 and the carb was gummed up bad and the filter and some lines had to be replaced.
Even after multiple cleanings of the carb (carb cleaner and boiling it with lemon juice) it still will not run right. It start fine, can rev to about 3/4 throttle but dies at full throttle. It runs fine anywhere from 0 throttle to 75%...but you also have to adjust the throttle slowly...do it fast (going up) and it will die.
Anyway, that what I have to work with. I stumbled on a webpage talking about fuel vaporize systems...which basically allow you to bypass the carb.
The idea seems simple and sound...have air going into your gas tank and then the carb inlet pulls both air and gas vapors directly from the tank. Since the fuel is already "vaporized" and mixed with air, all the carb needs to do is meter the charge going in via the butterfly.
Most of the setups Ive seen used some other container as a fuel tank. But I figure I can use the stock fuel tank and make a air inlet line and a vapor fuel exit line go through the gas cap.
I am a bit skeptical. While I believe that a engine will run on vapors...having the ratio of fuel/air be right might not be so easy. But, since I have a carb that wont work right and would cost over $100 to replace and trying a vapor setup wont cost more than $10 in parts from a hardware store I figure why not try it and see for myself.
Basically, I plan to put to barbed hose fitting through the gas tank cap. One will put a hose down into the tank and have a air filter on the outside. The other will take air/vapor from the tank directly to the carb inlet. This line will have a "T" fitting on it and a ball valve on the other side of the "T". The purpose of that valve will be so I can adjust the fuel/air mixture. If it runs rich, I can open the valve a touch and add air to the mixture being pulled from the tank.
anyone wanna give their thoughts on if/how well it will work?
