gas tank?
1992suburban
I wanna go FAST!!
Sanford, NC
depends how much work you wanna do. vs how much money you wanna spend
they charge about 80 bux to remove governor drill jet install parts basically they can/will do everything xcept bolt the motor in your cart..
stoutracing is a good splace for clones as well..
there are MANY choices
kazkepox
Pro- one idea to the next
Panama City, Florida
well, I want to spend less money than I Have to, because I like doing my own work. But, i want to be able to find a clone for about 100$ so that I can pour another 100 into it
1992suburban
I wanna go FAST!!
Sanford, NC
thats about all I would spend as well.. 100 for motor and 100 for parts
air filter and adapter = 25bux
header and muffler = 28bux
18lb springs = 10-12bux
cam = 50 bux
drill jet FREE
advance timing (file keyway .006" equals 1degree advance) FREE
keep RPMS under 6000 and you wont "need" rod and flywheel
I have done MOST of these mods to mine.. do a little at a time so you can see/feel what makes the biggest change
you need to run against the clock or a buddy to judge the improvement though becasue they will be subtle
kazkepox
ok so parts are easy its just finding the right [;ace to buy the clone, my dad had been working in pensacola so when my b-day comes aorund i might get him to run by freight and pick up a blue clone for 120$
squat251
so then, your building a race cart? or just a fun cart?
because if its a for fun only, you might be better off going to the local junk yard and finding an old lawn tractor or snowmobile. (or jetski, if you dont have snow there)
