gas tank
buddyochoa
Not Senior Yet
Thorn Hill, TN
Anyone know where you find good quality fuel tanks for karts? I'd like to use something that has more capacity then the tiny ones they put on the top of motors.
r97
Measure twice cut once
Massachusetts, USA
If you are looking for large capacity a generator gas tank could be what you're looking for. You could also consider running twin gas tanks. Something like this might work, I believe bighead had a similar tank setup on a Manco Dingo. Are you having trouble with running out of fuel during rides? Unless you are riding for hours I would just keep the stock one for many reasons.
Bluethunder3320
fuel goes bad fast so you cant have a huge tank and only fill up once a year. unless you put stabilizer in.. but still not a good idea. stock tanks usually last a few hours, are you going on trips longer than that?
souperman000
Westlake Village, CA
There is (or was) a gallon tank on bmi for a couple bucks. Are you looking for somethong bigger than that?
If you are concerned with having too big of a tank, you could measure your engines fuel economy.
buddyochoa
Not Senior Yet
Thorn Hill, TN
I'm still in the design phase, so as much as i'd like to be able to take picture I have nothing to photograph yet. Going to be able to start in a few weeks, and hope to have everything I need to order planned out.
buddyochoa
Not Senior Yet
Thorn Hill, TN
I don't have an engine yet, though if I know that the pulse jet carbs don't work with the gas tank I want to use, I can avoid those.
fowler
Bullsbrook West Aus
There is a range of things u could use
An air tank
Fire extinguisher
Some one even used an ammo box
If u want a premade one then duel tanks would be the way otherwise u can use anything u can weld to
