robbie
Traditionally, rural folks burn their trash and throw everything that's nonflammable into a ditch somewhere. I've found several garbage dumps on my property, with old furniture, appliances, jars and cans, and lots of roofing shingles for some reason. I don't care for this kind of dumping, so we do the same thing we did when I was a kid. We use a burn barrel, which is dumped at the landfill when full.
Burn barrels tend to fill quickly when things don't get burned completely, which is always. It's just a barrel with holes in it for air induction, and it's not efficient.
I have always wanted to build an incinerator for cleaner burning and to get more use out of a barrel. I had an unusable 80 gallon pressure tank left by the former owner of the property. I had always thought to build a barbecue out of it, but it turned out to be too thin. So I made holes in the bottom, cut a door, and cut a big hole in the top. Then I added feet to sit on top of a barrel. It's pretty simple, and it works great. It gets so hot that the metal glows.
In the photos you can see a typical burn barrel, then the incinerator. There's one photo that doesn't look so obvious. It shows the inside of the incinerator with not-very-visible holes in the bottom.
