briggsandstratton123
i have a spring loaded handle starter 126 2 stroke motor that apparently has usebale power and can run horizontal but it doesn't seem to run i checked compression and spark plug which all seem good so i've sort of narrowed down the problem to the carb which i looked inside and looks perfectly clean and the jets are clear although in front of the primer button is a little pinhole that is constantly squirting out fuel when the fuel tap is on. is anyone familiar with these carbs or know of any service manuals for the carb, Thanks
