Why? Most Fun Power Models are dual bushing blocks. Bushings hold up fine to around 7500 RPM if i recall correctly. All my Briggs 5hp were dual bushing blocks and they worked great.
Just for clarification unless you are not understanding my argument. I do not feel it is worth placing aftermarket parts on a Briggs without dual bearings. I look at what you put into the engine and how well it will hold up to stress considering the investment.
If you drill some extra oiling holes, and are very careful with your motor, a plain bushing block will work just fine. That is all they had back in the day.
A somewhat more readily available block would be a single bearing, DU bushing block. Bearing in the sidecover, and an actual bushing installed in the flywheel side.
A great deal of the standard 5hp Briggs you'll see a dual bushing set-up, on some you will see 1 side of the crank on the inside of the engine sits in a bushing, the other rides on a bearing. On industrial and raptor blocks they have 2 bearings which support the shaft which allows for better operation at higher rpm and enhanced lifespan of the engine itself. When racing Briggs engines were popular in Houston 5-10 years ago we couldn't keep dual bearing blocks on the shelf at 100 dollars a block. I've edited this because what I said did not make as much sense as it should have.
