I have an old Kart Wheels fun kart that had one old lawn mower wheel and 3 split rims. I'd like to replace the lawn mower wheel but all my hubs have 4 3/8 holes on a 3.125 bolt circle instead of the standard 2 7/8 or 2 13/16 you normally see. I bought one with a 2 7/8 bolt circle thinking it was correct but it's not. I also need a 35 chain sprocket with the same pattern. I've come up empty in my searches. Any help would be greatly appreciated.
Also, another thought would be to just replace the hub/rim assembly with just a solid steel rim that accepts bearings. You may need to install a spacer for fine tuning on the spindles. Most spindles are 5/8".
