should... that's the point..
a free revving engine turns WAAAY higher than a load revving engine, you're aware of that, right?
6k rpm... not impossible though, but under load... difficult without modifications...
Also dangerous without mods like a billet conrod at least.
what's the horsepower of your engine now.. and please don't say 6hp,
since if so.. I can wipe the 50 mph off the table right now.
18" rear wheel... let's assume 100kg in total (you and the bike) [220 lbs]
since you said you
"should" reach 44mph with a stock clutch, that means you run #40 chain, a ten tooth clutch (or you assumed that) and a 7.2:1 ratio
since mathematically that means 71.82 km/h or 44.62 mph
here's the point my calculator asks to lower the ratio down to 8.8:1 to NOT shred the clutch or a tc-belt
and we're back at 58.76 km/h or 36.51 mph
Anyways.. TC series 30.. (Tav kit 6" driven)
No wining of my calculator... sooo the TC can compensate your rear wheel.
personally I still doubt, it'll reach the 6k rpm because of the drag..
but if it does... the 50 mph are at least within reach ...
KartInfo by kartcalc.net:
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 45.72 cm | 18 in[/B]
[I]Total weight[/I]: [B] 100 kg | 220.46 lbs[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Original HP[/I]: [B] 6[/B]
[I]Asummed HP[/I]: [B] ~6.6[/B]
[I]Torque[/I]: [B] 11.87 Nm | 8.75 ft lbf[/B]
[I]RPM[/I]: [B] 6000[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B]
[INDENT][I]Final ratio[/I]: [B] 7.2:1[/B]
[I]TC type[/I]: [B] series 30 6" driven[/B]
[I]Lowest ratio[/I]: [B] 19.44:1[/B]
[I]Highest ratio[/I]: [B] 6.48:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Max Wheel Torque[/I]: [B] 230.75 Nm | 170.19 ft lbf[/B]
[I]Min Wheel Torque[/I]: [B] 76.92 Nm | 56.73 ft lbf[/B]
[I]Acceleration[/I]: [B] 5.73 m/s² | 18.8 ft/s²[/B]
[I]Top Speed[/I]: [B] 79.8 km/h | 49.58 mph[/B]
[/INDENT]
[/FONT]
