I searched the forum first and literally nothing relevant came up, so this should probably help quite a few people down the line.
There are many fuel tank sealants out there for steel tanks whether it is to seal over rust, plug pinholes and seal over rust, or sealing a new raw tank to prevent rust from forming, gasoline, and diesel.
The ones I recognise by name what they are would be... Kreem, Red-Kote, and Por 15.
While the tank on my Mule is solid and without pinholes doing an edescopy on it revealed it has a fair bit of rust in the lower half. It's appears to be only surface rust.
I need recommendations of what the best option is for sealing tank that really can't be cleaned out due to design. It seems to have some sort of divider, maybe a reserve partition below the E on the gauge, idk. It is a relatively large tank as well.
